On my L76 motor I have a correct replacement 2818-1 carb.
Everything I've read on here indicates that my vacuum can on the distributor should be hooked up to the FULL vacuum port, not a PORTED vacuum port on the carb which i thought mine was.
I was at a tuning session yesterday and had Lars (from the "other" site) tune my car and she is running better than she ever has before but after checking everything he determined that the port on my carb is only a ported vacuum port, not a full vacuum port and my carb has no full vacuum port available which was surprising.
Isn't the 2818-1 suppose to be a full vacuum port? If not, how much am I losing in performance by only having a ported vacuum controlling my vacuum advance? I do have a plugged hole on my intake right behind the carb - would I be better off getting a fitting for that intake hole and running the vacuum advance directly off the intake manifold rather than the carb?
Any and all suggestions or advice is great appreciated as always!
