Okay here is the deal on the L98. The T-stat stock is a 195, therefore unless you have a lower temp T-stat the car should'nt run cooler then this temp. The primary colling fan comes on at 208 or 210, something crazy like that. If you have a booster fan in front of the radiator, then that will kick on at 220.
Most L98's run hot, this way the emissions are not as bad, they were designed to run hot. Most people do not like this, so they put in a cooler T-stat, most popular is a 160, or 180. Then they by a chip, or have a switch to turn the cooling fans on earilier. Personally, for me this is the only way to go. I have a 160 T-stat in my car, and the fans come on at 175. My car runs good, not too hot, and not to cold.
As mentioned before, cleaning the radiator is very important, as is flushing the system periodically.
