S
SurfnSun
Notice the spacing between the door and hood.
ET-Viper, whats your take?
Should not have been painted. If you look close at the door, the upper and lower are different colors. The hood and gill are also different. The mirrors have to go!Not sure if it's normal on an Aerobody car, but the door handles have been painted too...
Actually C1's,C2's and C3's are the Real Bears to get panels aligned before Bonding!!! C4's, C5's, and C6's are a Piece of Cake!!!They have allot more adjustment,That car just needs someone to adjust everything RIGHT,and learn how to match paint!!!Factory lines are much better than that. C-4's are very difficult to repair compared to C-3's or C-5's and wouldn't attempt unless you have experience or very experienced tech. My white car was a factory official car and has very good gaps. Expect that #59 will meet same specs when finished.![]()
Yeah a lazier system is nice, but if you have 3-4 different guys using it they can be more trouble than there worth keeping calibrated!!!! I use the Mitchel books and tram gages with a MM tape!!! I can get them with in 1 MM and the factory gives you at least 2-6 depending where it's at,it just takes me longer!! 1 MM is 39/1000th's,if it's that close I can get the alignments No Problem!!!!!Problem is when inner structure gets damaged and has to be properly repaired and returned to factory appearance, especially cowl, front frame rails and hood latch supports. Twist or diamond can sometimes fool you. Takes very good laser alignment equipment.
