Original Roller Rocker #'s
  • Thread starter Thread starter dcaatc
D
dcaatc
Hello Everyone,
Does anyone know what the factory original pre-recall LT4 "roller rocker" numbers were? Does anyone have any idea where I can find this information? I pulled the rocker cover yesterday and the only numbers we could find on the "roller rockers" were 33-96 and 34-96 in no particular order! I found a sticker on my door (not in the correct place) showing that the first recall campaign 96-C-07 was completed! However, if that was the case, the "roller rocker" part number would be 12551311. My problem is definitely a failing bearing in the roller rocker which makes a tapping noise! Any help on the original numbers would certainly help!
Thank you,
DCAATC
