S
SurfnSun
Well I went out and rented a vac gauge tonight. I pulled off the two lines the run off the plenum, the one closest to the firewall would not hold any vac at all. I could pump it up to 10 or 15 psi and it would bleed off in a matter of seconds. The front one would hold vac with a very very very slow bleed off...should that one be of a concern as well?
Now back to the one I know is bad, Im pretty sure its the one that runs to the driver's side turbo. I cant see where the line runs, but it looks like the whole line is metal. Due to the position of it I was unable in my quick diagnosis hook my vac guage to the metal part. I went off of the rubber portion that runs under the plenum.
I was also unable to get a vac reading on the wastegates themselves due to location.
Any advice?
Any advice?
