E
embflieger
I'm trying to figure out how badly damaged my engine might be. Yesterday evening I started driving home from the airport, and my console display went out. This happens sometimes (187,000+ miles and a suite of gremlins), and a well-placed smack to the dash is the usual remedy. The problem is that yesterday I was too busy with traffic to deliver the remedial punch. When I did, the coolant temperature was showing 270 degrees, and the oil temp had started climbing. The serpentine belt was gone.
Immediately pulling off I-77, I got to the top of the exit ramp and stalled. A pair of Samaritans helped me push the Corvette into a parking lot. I opened the hood, saw the belt, and replaced it. The engine started, and all seemed right. Two miles later the water temp was rapidly rising again, and I saw the "Low Coolant" light. I stopped the car and topped off the coolant. It was full dark by this time, and I think I over-filled it. Two miles later the car was back in my driveway, but leaking coolant.
Not being sure how long the engine was hot, how can I tell what if any damage was done? It would seem that at least (and if I'm very lucky) the water pump's failed. After I replaced the serpentine belt the oil temp never read high, but the coolant temperature always climbed.
