Grizzly
- Joined
- Aug 23, 2002
- Messages
- 430
- Location
- Centerville, PA, USA
- Corvette
- 1967 Marlboro Maroon Coupe, 1992 White Convertible
I participated in my first parade with the 67. It was fun showing off! All of the other Vettes in the parade were much newer and no one else had side pipes.
I had two problems from the slow moving parade, a clutch that was getting pretty hot and slipping and and engine into the red zone. Don't know if I can do much about the clutch, but the engine overheating maybe can be helped.
Any of you put an auxiliary fan on the engine for parade work? How about on the front where you can't see it as much? I also thought about making some sort of blocks so I could hold the hood open a little. How about that water wetter stuff? The car normally runs way below the 210 degree marking on the gauge. Oh and it was about 75 degrees that night.
I always heard that big blocks were a problem, but I thought a 327/300hp would not be a problem.
