M
mdsbch
I've looked through several threads and can't seem to find anyone that has had problems with their cat overheating. I have an '85 Corvette and tuned it up about 2 months ago (plug, rotor and cap, capacitor, plug wires, set timing, idle speed, etc.) and it was running great. A week ago I started it up to warm up and it was very hard to start (I had to run it around 1500 rpm to keep it running) then I noticed some smoke from under neath and the cat was glowing red hot (burned a hole in some old carpet that it is parked on). I figured from doing some research that it was probably plugged. I replaced it today and the same thing it was hard starting and this time it was not only glowing red but there were like little pieces of honey comb type material that came out of the tailpipes. Looking in my Helm's manual it talks about the cat overheating if there is continuous air flow to the cat or exhaust manifold from the A.I.R. pump tube. I'm sure that someone must have had or seen this problem. It wories me that it could catch the car on fire if it isn't fixed, but am not sure where to start trouble shooting without causing a fire. Please help. Thanks.
