ZZRider
I had been having some overheating problems, I believe in part due to my car being lowered significantly and leaving very little room in front for air to come in under the front of the car after my engine change/mods. I checked the fans and both worked normally at low/high speed and temp onset. Last week I removed the front housings around the foglights and placed the Z06 screens. (I used screws to secure them, others have simplified this by just using velcro). Here are the temp changes I've seen over the past week.
Temp cruising before 180-195
Temp stopped before 220-245+ (very very rapid rise)
Temp cruising after 175-185
Temp stopped after 185-205 (very slow rise)
Now I know Dave Hill has said the Z06 screens do not allow for significant air flow, but I must say I am pleased with what I have found for mine. (If this would not have worked I would have next raised the front end 1/2 inch or so.)
I suppose this is just a FYI. Most of you are unlikely to have this problem.
