JohnGrawcock
- Joined
- Sep 22, 2003
- Messages
- 318
- Location
- Kokomo, IN
- Corvette
- Claret 82, Light Bronze 84, and Black 69 Vert
I've been fighting an over heating problem on my 79 Chevy pickup. It can sit parked and idle all day without getting hot but after 4 or 5 miles at 60mph the temp gauge is pegged. It just doesn't act like the typical cooling system problem. Just to see what it would do I flushed and refilled the system and then took it out on the road with no thermostat. It took longer but it still overheated.
Could it be that I'm running to lean at speed and need to work on the carb? I'm going to pull a plug and check as soon as it cools. I'll also double check the belt tension. Does anyone else have suggestions?
