Hrtbeat1
Help!!!
I developed an overheating problem. I found the water pump had a bad rear seal and replaced it. While I was at it I replaced the timing chain and gears. Every thing is dead on timing wise. I took the radiator out and gave it some much needed TLC, cleaned and straightened all the fins, and did a thorough check of the cooling system. All looked good. I decided to go with a 160 degree thermostat and fan switch sensor. After installing these the car started fine but the fans never kicked on and once the thermostat opened the temp gauge pegged. I tried going back to the original setup and now the temp gauge hovers near 225 or so. I can get one fan to kick in with the AC on but not the other. Both fans spin when grounding the "A" and "B" terminals of the ALCL conector in diagonistic mode. Both fan relays have also been replaced and swapped.
I guess my question is Do you have to modify the EPROM to take advantage of a lower Thermostat/Fan Switch? Or is there a chance that my ECM is faulty?
By the way this is a 90 L98 Auto 110K compression all cylinders 195 (#7) to 210 (#1,2,4) with #3,5,6,8 in the 200-205 range.
Thanks for any help or advise. Magmotor you out there?
