overheating Z06
CLIFF
New member
florida east coast
2003 black Zo6
I have a 2003 Z06 that allways ran at 190 degrees now it started to run198 - 210
i checked to see if the fans were coming on and they did not turn on at 200 until i turned on the A.C. with the stock 192 thermostat when should the fan(s) come on? i was thinking of puting in a 170 degree stat and wondering if it would cause any problems like with the computer?
thanks for any info you can supply
Cliff
I just got my car but it seems to jump up to 220 in traffic and then get back around 190ish once I am cruising....I wouldn't worry too much, sounds like mine is running a little warmer than yours. Someone else with more experience will chime in soon! Take it easy.....
c4c5specialist said:
Hi there,
Fans are on at 228 unless you turn the AC on.
220 in city driving is normal and should not be confused.
You are normal.
A
llthebest, c4c5
Thanks for the info but i was wondering why it started running at 200+ when it was allways was at 190??
Check in front of your condensor. You might have picked up a plastic bag or some other debris from the road.
Save The Wave! :w
The C5 sucks up any & everything on the road, leaves, plastic bags..small children, etc. Clean the radiator then install some screening to keep the road crap out.
