Paging Turbocat
  • Thread starter Thread starter SurfnSun
S
SurfnSun
I was wondering if you might be able to supply some pics of your t3/t4 installation with the racegate setup.
Myself and 542C2 would be interested in seeing it.
Josh
yea, if someone could teach me how to post the pictures. Besides, I've gone over the edge- 427 motown aluminum small block is now going in .
DAAAAAAAAMN!!!!!:eek :eek :eek :eek That thing will be CRAZY!!!!
email them to SurfnSun1@aol.com and I'll host and post them or below the text reply box there is an Attach Files feature you can use also.
Did you mount them as the originals were or did or if you had to fab up a new bypass route?
Im am hoping that with a bit of machining to the turbo the racegate will be able to bolt up. The pull style valve appears to be making it tough to run a different gate without somewhat significant mods.
Turbocat - the easiest way to post a pic is to simply attach it to your text post.
Looking down in additional options (under the "submit reply" button, you will see a box to attach files. Click "manage attachments" and it will then give you a box, next to it, browse...
Browse allows you to "pull" an image from various locations - Locations such as your hard drive, CD, disc, etc.
As long as the max image size is smaller than 85kb, it will go - I have even put a 64kb and a 7kb image together, since it was smaller than 85k, it went along w/ my text to be displayed.
Let me know if you have any questions about this, If you have multiple "big" pics, you may have to make numerous posts.
Hope this helps :m
Thanks guys, but I don't know how to get the pictures into the computer much less e-mail them. Lost the software to my digital camera for direct hook to computer so I guess i'll have to get an adaptor to transfer my camera card to a floppy. Surf,I can see no way to mount new wastegates to your stock turbos-I looked at this option and found that the stock turbos have a small interior passage built into the turbine housing that makes them almost impossible to port. I just had to face the fact that the turbos would not work on a heavily modded motor.
