Space Cowboy
- Joined
- Oct 8, 2003
- Messages
- 408
- Location
- Houston Texas
- Corvette
- 1968 Convertible - Candy Apple - 427/475+
I have a private paint/body shop paint my 68. I'm questioning if he properly allowed for wait times for the primer and paints to cure between coats. I paid to have a fairly expensive epoxy primer to be used (I don't have proof that he used it though), but I've been told that you have to let this type of primer cure for one - two weeks before applying any base coats. Well... He didn't. As a matter of fact I don't even think he waited even 12 hours until he wet sanded and started applying the first base coat.
Those of you with a lot of experience with painting, I would appreciate your input as to what is the proper procedure. I also assumed you waited for cure time (unless some type of hardening agent is used) between each base coats. He claims he primed, wet sanded, based, and cleared in less than a 24 hour period.
I'm not a pro by far, but I watch enough auto rebuild shows on tv to know what is a normal process. I just don't see how its possible to do what he did in that amount of time.
Oh... by the way... this is a candy apple application too!
Thanks all.
Thanks all.
