Bose Speakers
Be careful using those Bose speakers. They are 2 ohm impedence, and some amps will overheat with such a low figure. I found some Kenwood 4 ohm speakers that fit into the Bose enclosures. The Bose speaker enclosures are very good!
If you put that switch in the orange wire at the antenna relay, you can switch between "Automatic" and "Hold That Position". H.T.P. can be up. down, or anyplace you want it. The antenna relay is under the trim piece at the hatch latch, on the left side of the car. I like to leave my antenna up about 12". If my reception is weak (hardly ever), I flip the switch and the antenna goes up.
If you put the switch in the antenna control wire to the head unit, you'll have a choice of "Automatic" or "Down".
