minifridge1138
Hey everyone,
I need to adjust my parking brake because it isn't holding very well.
I have the service manual, but i'm a little confused by it.
It says to loosen the equalizer check nuts, but i'm not sure where those are.
I understand the part about rotating the disk until the adjusting screw can be seen. But then it says: "Insert an adjusting tool or screwdriver through the hole in the disc and tighten the adjusting screw by moving your hand away from the floor on both the left and right sides."
What does it mean "moving your hand away from the floor"?
All help is appreciated!
