ibuyvettes
Ok if what your looking for is major and not listed it's gone. If you need something minor I may have it still as there are like a million little supports/relays/etc on this thing. All prices plus shipping.
Lower rocker panel covers 30.00 each.
Internal dash radio/BCM bracket 20.00
Door hinges no sag 30.00 per side.
automatic shifter 50.00
third brake light coupe 15.00
parking brake handle assembly 50.00
Steering wheel good shape, no air bag has horn buttons. 75.00
fuel tank, 100.00 (cannot ship)
dual electric cooling fans, 100.00
windsheild wiper motor, 50.00
lower radiator support, 80.00
upper radiator support 80.00
wiper arms 20.00 for both.
three piece rear cargo trim 60.00
pass side a-pillar trim 15.00
Brake booster 100.00
auto gas brake pedal assembly 100.00
ABS ASR pump, good to have a spare as a new one is 1500.00, 200.00, now 150.00
ABS computer 75.00 now 50.00
Airbag control module part number 1228874 75.00, now 50.00
Entire LT1 dual exhaust system everything but the manifolds. all one welded piece. 150.00 pick up only. Now 100.00
dash core you need this if your converting an 84-89 dash to a 90-96 style (don't ask me how this is done I don't know I've just seen it) 80.00 now 50.00
ASR throttle servo (or whatever it's called, it sits under that plastic cover that says ASR under the hood 50.00, now 30.00
cruise control vacuum diaphram 30.00 now 20.00
rear top brackets 10.00
blower motor 20.00
coolant recovery tank 15.00
Driveshaft dana 36 100.00 now 30.00
fuse cover 10.00
trim that the fuse cover snaps into 12.00
driver side dash cover (the part that has the hood openening symbol on it). 12.00
Leather seats Black (No tracks) 400.00 pass side nice, drivers has a few cut like slits about an inch long on the bottom, so please ask for pics of these. now 299.00
Wheels 400.00 actually 94 wheels Machined 8.5x17 front and 9.5x17 rears (sawblades)nice shape some minor rashing on the lips,has good tires on fronts and bad one's on the rears. NOW 300.00
Dual Power seat control 50.00 NOW 35.00
Headlight/traction control, control 50.00 now 35.00
radiator 50.00 NOW 30.00
Pass side door with glass window motor lock soleniod, and mirror 250.00 (Bright red) No damage (drivers side cost 160.00 to send to Miami after 60 bucks worth of bubble wrap). now 200.00
Left side console cover 50.00 NOW 30.00
console core 25.00 NOW 20.00
Frame (once stripped) 500.00 comes with title. Now 250.00
instrument bezel 20.00 NOW 15.00
drivers side kick panel metal support (anyone know the name?) 25.00 NOW 05.00
Rear compartment storage doors 50.00 NOW 30.00
rear hatch glass 250.00 (please pick this up). NOW 150.00
Hood hinges 20.00 now 15.00
pass side halo 40.00 with light cover, drivers side halo is cracked but you can have that too. NOW 20.00
Rear impact bar 200.00 NOW 120.00
rear absorber 30.00 NOW 20.00
Rear splash guards 30.00 each NOW 20.00 each.
blower motor 20.00
fuse cover 10.00
