Question: Pass window won't roll up
  • Thread starter Thread starter vettehead 1
V
vettehead 1
I have a 2005 Coupe and when the passenger door is opened, the widow rolls down as needed. But when the door is shut, it fails to roll back up like it's suppose to. Driver side operates correctly.
Any one else have this problem?
;shrug
It sounds like the window has lost its indexing. If the battery has been replaced (or died) it's possible the window needds to be re-indexed.
Get in car, close doors, put vehicle in accessory mode. Roll one the window all the way up, let go of switch, then hold the button up again for 5 to seven seconds. Try opening the door and see if it indexes correctly. That MIGHT fix it. If not it might mean a trip to the dealer. I have seen some widows act very strange with with low batteries.
Just a thought,
Ron
Ron:
I finally got around to checking the window today. Did as you instructed, and that took care of it. Works fine now.
thanks
Phil
