PASSEBGER SIDE VALVE COVER GROMET
EOLIVER
SAN DIEGO, CA
1989 DARK BLU METALIC SIX SPEED CONV
Does anyone know if the passengfer side valve cover breather gromet can be removed like the driver side (by just pulling it straight out) or does the valve cover have to be removed. Als, is their supposed to be to pvc valves of just one on 1989 l98
tyrel
Portland
Well, the grommet won't pull straight out, it is a pressure-fit piece of rubber, I usually use needle nose pliers or pry it out carefully with a standard screwdriver. The pcv valve goes on the driver side valve cover, the passenger side is just a tube that runs to the throttle body.
W
WNH
But don't expect to re-use it.
It may rip, they sell replacements at most auto parts stores.
