Passenger side door release is sloppy....
  • Thread starter Thread starter Sams '66
S
Sams '66
Getting much worse lately.........It sort of flops around and you really have to pull ALL the way back to get the door to open.......
How difficult is the repair.......I have never taken off my door panels to have a look inside.......What is the likely problem??
thanks..
Sams '66 said:
Getting much worse lately.........It sot of flops around and you really have to pull ALL the way back to get the door to open.......
thanks..
If it's like the ones I've had experience with, the problem is wear due to usage and age. If it still opens OK with the outside button, but the inside latch is as you describe, there may be a fix for the old mechanism, but it'll require removal of the door panel and door latch mechanism.
The pushbutton for the outside release contacts the release arm at a flat point, therefore, not much wear at this point over the years. However, the inside release operates the same mechanism with two pieces of metal contacting edge-to-edge (as I best remember), and as a result the contact point is much smaller and more prone to wear over the many years these cars have been in operation (doubt the General ever expected them to have the following they have today).
I removed my latch mechanism, located the point where the front release contacts the mechanism, and built the wear point up with a welder several years ago. So far it's worked great, no further problems. And as best as I remember, that was before wire-feed welders were widely available, which would make the job much simpler. Once the door panel and latch mechanism is removed, the wear point I described is much easier to locate.
That's my experience, hope it's of some help to you & any other Forum readers who may be having the same problem. Of course, a new latching mechanism and release lever would provide the same cure, but I'm not sure how available they may be and at what cost. Best of Luck . . . .:)
(PS My experience is that usually the problem is with the driver's side, almost certainly due to higher usage it receives over the years. Apparently not so in your case.)
tigernut said:
Sam,
Replacing this part:
http://www.corvette-paragon.com/catalog/Product.aspx?id=8C0DD693-57B5-44AE-A796-EAC27706CB74
fixed your described problem for me. Easy to do, as long as you know how to remove the door panel.
Doug
Hope it's that simple for you, Sam. But the problem I'm referring to, and where your problem may be, is not in the side pull mechanism, but rather in the door latch itself. If so, that requires a different fix. Once you get the door panel off, you should be able to determine exactly where your problem lies by watching the operation of the mechanism. :)
Of course, if your luck runs like mine does, it may turn out you need BOTH items repaired/replaced! Hope not!:confused
tigernut said:
Sam,
Doug
This is the parts I replaced in my doors also to correct the problem you are describing.
But as always one thing leads to another and while I had my door apart I replaced the window channel material and removed the door lock mecanism and soaked it in a can of carburator cleaner overnight.I re lubed them and let me tell you the results were spectacular.Well worth the effort of soaking the door locking mecanism.
Becarefull removing the door lock knob on the inside of the car Its not too easey to get off(High chance of cracking the door panel)
Sams '66 said:
Wish I knew how to weld!!!!
Thanks!!
With the availability of these inexspencive wire feed welders anybody can weld.
I can comfortably say that with in about 6 hours (on and off different days ) I have taught my 10 year old son the fundamentals of wire welding.The rest of his skill level will come from practice and exspereance,If you want to learn how to weld invest in one of these machines .
I was taught how to stick and gas weld by my father and grandfather at an earley age
