V
vettekingz06
I need some help---My 2003 z06 instantly started running rough and I had to have it towed home. I retrieved the codes and they are PCM code 0106--manifold absolute pressure perf. and PCM 0300 which is random misfire. It seems to have a vacuum leak. I have looked at the PCV and it's ok--also capped off the vacuum line going to the air conditioning but that didn't help. I need some help to find the problem---Thanks in advance
