Haven't received in PMs in a number of days but...
Frankly, at this point in time, I'm surprised that people calibrating for L98s have any "secrets". I'm interested to learn what you know that the hundreds, maybe thousands, if folks who've done cals for L98s never discovered.
In re: the "pump shot" biz...how do you know without wideband data whether or not the L98 your doing a cal for is rich or lean at tip-in or during larger increases in throttle opening such that you need to change the "pump shot"?
With respect to lower fan-ons and modified engines, lower fan-ons and lower temp 'stats are great but only if the rest of the cooling system can actually cool down to the thermostat value. If you're calibrating for an engine for which your not sure if it has a bigger radiator, do you leave the spark and KR alone, in case the car does not have a radiator big enough to cool a modified engine during sustained high part throttle or WOT operation?
On spark cal, do you copy the high-octane table data into the low-octane table?
On the TCC work, if the car is not a drag racer and is hi-po street, autocross or track car, do you still change convertor lock-up?
Is all your work with L98 or can you also do chips for 2G LT1, the LT4 and the LT5?
