Jack
- Joined
- Dec 27, 2000
- Messages
- 1,825
- Location
- Florence, SC (Timmonsville SC)
- Corvette
- 71 War Bonnet Yellow VERT 71 BH Blue CPE (SOLD)
As I began to assemble a small block stroker I couldn't find pics that represented how the connecting rods should be ground (cam-clearanced) ... necessary to prevent rod-to-cam interference. So, after I did mine I shot some pics. I'm using the rods in a 3.800" stroke sbc with a MILD cam similar to an L-82 profile (installed straight up). If and How you modify your stroker's rods will depend on your cam, your rods, your crank; I offer this as simply a guide. I ground them using both a carbide burr & stone in a 1/4" air-driven die grinder. These posts are my first attempt at posting pics on the net ... lemme know if you have problems accessing them.
Please find attached 3 pics of GM "pink" 5.7" long connecting rods for sbc that have been cam-clearanced on side facing cam. Pics show side-by-side comparison to UN-ground side that faces oil pan rail. P1 shows ground side on bottom rod, P2 & P3 shows ground side(s) on left rod(s).
http://www.imagestation.com/picture/sraid20/p95fb733a02251f858d80be84b61b2390/fdbd8628.jpg.orig.jpg
http://www.imagestation.com/picture/sraid20/peec0cdcd3b2d883aa568ef490aa6768d/fdbd861b.jpg.orig.jpg
JACK:gap
JACK:gap
