- Thread starter
- #21
Peer81
There is almost no difference between the plastic and coper lines in termes of oil pressure readings. But the plastic line was 3mm with a very flimsy compression nut which I broke the first time around, the copper line is 5mm with a more solid compression nut. The problem was I broke the 3mm compression nut so even at idle oil was getting all around the place.
As I remember it is a high volume / pressure oil pump but don't know the spring it has. The other website says lowering the resistors value by half would make the gauge's "pressure" go up by 2x.
But I hope to test the oil temp tomorrow to see how far off that one is
Greetings Peter
Greetings Peter
