S
secondchance
Need Help!!!
Yesterday, I pulled the plenum to correct vacuum leak. In doing so, accidentally pulled the wires off TPS. Three wires, dk blue, black and grey. I belive I got the correct connections: A-Black, B-dk. Blue and C-Grey. Now, motor cranks but won't fire. Whats even more strange is even when I release the ignition key, starter continues to run for 5-6 seconds. Could it be wrong connection for TPS? Or maybe, I accidentally disconnected wires to Crank Position Sensor?
If anyone could verify TPS wire colors to a, b, and c terminal, I would appreciate it.
Also, where is the connection for the crank position sensor?
Thanks.
Thanks.
