widewhites
I have a some of questions on spark plug gaps, RPM’s and fuel consumption. I gapped my plugs (R45TS) to the correct gap-.45 (running HEI). After researching, and realizing that the gap was previously at .35, I regapped. Timed the engine everything is good. BUT, my RPM’s are now way off, before I would hit 3000 RPM’s when I got to 60 mph and fuel consumption was okay for your average 350 Chevy engine gulp. Now I hit 50 mph and am at 3000 RPM’s and forget mileage. Gas is going through the roof. You can actually see the gauge move to empty when you are driving 60 – 65 mph (35-3700 RPM’s) . The response if good, better than before but is this normal for the RPM’s to increase due to the increased plug gap. I have the older Torker package with a 650 carb, an automatic trans. The reason I regapped was because I was having to go through plugs every 5 months. Any suggestions, comments??? I have run .35 gap for about 4 years.
I was also always asked why I would hit 3000 RPM’s at 60 MPH. I always thought that was normal……….
Thanks guys!!!!!!!!!
