Popping / backfiring in carb
getavette
RI
1972 Coupe
I had a tune-up w/ timing adjust and car ran great for about a week. It then started backfiring from carb under acceleration. Mechanic I talked to seems to think it is a broken cam but said the only way to know for sure is to pull valve covers. Any advice on this would be appreciated.
72 Automatic 350 w/ Holley carb
Bob
Broken cam as in the main engine cam?
No way! The engine would destroy itself in a few rotations under that problem. Maybe he meant a cam on the carb linkage? No - he said pull the valve covers to look, so he must mean the real cam...wow...that's silly! Even a worn lobe doesn't do this generally.
While it's not a bad idea to pull the covers and turn the engine over while watching them for seemingly decent operation, I would more suspect something on the order of my favorite problem of the season - a blown head gasket.
Under acceleration only sounds to me a little more like a badly adjusted vaccum or sticking mechanical advance though.
Go through the basics - look at everything in the distributor, make sure the mech advance seems to work cleanly and that the rotor is in good shape and not wobbling. Make sure the distributor cap doesn't have any tracks in it or any cracks. Make sure the vacuum line to the vac advance is connected and not leaking. Double check the timing. Check each plug wire for contact with another or a sharp edge on the engine. Somebody over on CF (I think) recently had a nightmare from some simple bad plug wires - but they were high grade ones.
Those backfires have probably wiped out your carb's power valve that give you good mid throttle response and will result in a surging and falling of rpm at idle. That alone can cause a temporary lean out under acceleration which can cause detonation - but not usually a backfire.
When you do look under the valve covers, look at each valvespring to see if any look shorter. An unseating intake valve from a collapsed spring can cause this. You also have the pleasant options of bent valves, bent pushrods, badly failed valve guides - a whole WORLD of messy grief! :D
If you have a vacuum gauge, note how it acts under idle, when revving it, etc. A lot can be told regarding valve seating and such from a twitch of a few inHg or a very low reading. The Chilton manuals and other such references usually have a little chart on what each vacuum condition may indicate.
If all of these "hour long checkup" things yield nothing, run a compression test to see if one of the cylinders is blowing its stuff into another from a blown head gasket.
Other evil things could be a worn or stretched timing chain, resulting in your apparent timing being much greater than you thought from the marks with the timing light. If it's too far advanced - it backfires, if it's too far retarded - it afterfires.
BTW, are there any other symptoms? Overheating? Air blowing out overflow?
Worn camshafts is a common problem on SB Chevy, a worn exhaust lobe will cause this kind of problem. The sound is like a constant flap-flap-flap in the carb. Take of the valve covers and crank the engine and you will probably see that one or more of the rockers don't move.
I sure agree to check all the easy things first. I'd look real good in that distributor cap for a track or crack between two terminals. Other possibilities under the valve cover could be a broken rocker arm or even a pulled stud if they are not screw in. A compression check could be done to check for a burned exhaust valve and maybe help indicate which cylinder to look for a problem in. Was anything done under the hood that could have resulted in plug wires being switched? Hope this helps.
Mike
Thanks for all the help everyone. Not being very mechanical I checked all the easy things and came up with nothing. I am just going to have to get it checked and hopefully it is not camshaft. They gave me a ballpark of $900 (ouch :cry ) if it is including new timing chain.
It was the cam shaft. The car now runs better than it ever did.
Just curious on this - did they have to pull the engine to change the cam or did they do it with the engine in the car?
