Johan
Hi all,
How can I tell if I have a posi rear end?
I´m installing the diff wich was drained, so my question really is what oil to use. Is it correct that I can use Gl-4 with non-posi but need GL-5 if I do have posi?
I do have the "use limited slip differential fluid only" plastic tag so maybe that's the answer to my first question?
If I do have posi, should I use an additive, or is that not necessary with a GL-5 oil?
Final question is how much oil to use? 4 pints or just add up to the hole?
/Johan
/Johan
