eoseitz
So I'm not really sure where to start. I hadn't drove my 74 in a while. It was really rainy for a while and I assumed water got in the gas. I used fuel stabilizer that claimed to remove water and my car ran better for a day. It will start up and idle fine. It will drive fine for a while, but after warming up, it wants to stall out when you slow down for stop signs or put it in park. I've readjusted the choke (it wasn't opening all the way) and changed out the fuel filter. It almost seems like it's not getting gas. If I shut the car off and pump the pedal about 15 times and start it back up, it runs ok for a little while usually. Could my fuel pump be going out? I haven't done a vacuum test, but my headlights seem to open and close without issues. The last time I changed my plugs and wires were about 3 years ago, but I haven't put vary many miles on the car at all. The wires are slightly burned right by the manifold, but after inspection there are no bare wires. Also, I'm guessing if it was this, the car would always run poorly, not just after warmup. Any ideas?
otfl
