The best is to replace the booster and master cyl in one if you are going they route.
Generally , if you have a booster problem , you will often hear a whoosh sound when braking and you would also have inconsistent braking pedal effort , ie sometimes the pedal will feel harder than other times.
Make quite sure it is your booster giving you grief. It could be the check valve going into the booster.
I asked my v8 supply house for a new booster/Mcyl and they imported a Cardone remanufactured unit for me (they thought i was price conscious) and it took me 4 hours to make it work , apart from fitting , it was a really rubbish part...
I am in South Africa so returning it would have been a mission
