Question: Power Locks
  • Thread starter Thread starter nosolos
N
nosolos
I just noticed a problem with the driver's side power locks. The door will unlock with the fob but will not lock. The same goes for the lock control button. the passenger side works fine. I noticed this when I checked to see if the door was locked and the door opened and the alarm went off. The key locks the door OK. Anybody had this probem?
Yup, my guess is you have a bad relay in the door module. Check here. My dad has this problem on his 03. The only thing he ran into is the link to the parts web site is www.digikey.com NOT www.digiking.com. If you know how to run a soldering iron this fix should only cost you a few bucks and a nice afternoon with your vett. :) I would recommend getting a few of those relays in-case the other side goes.
