1
1996man
Hey guys. This probably seems like a no brainer but i just want everyones input in case i missed something. I dont have a dyno pull to back up my theory but i beleive my LT4 is running a lot weaker than it should be. One big reason I suspect this is I raced JTB who dynos 284rwhp and the only way i was staying the smallest bit ahead of him was that i have a lot higher redline and was able to shift a lot later. We raced several times and each time was the same. I was only ahead by a nose. Granted I will give it to him that he is a good driver but that instance along with the fact i can only manage to seem to get 13.5@107 as a best at the drag strip, I think I am down a bit on power. My question is this. What thigns are often case the source of this problem? I know i have a lot of miles (142K) and some of the things i plan on doing in the near future are plugs, plug wires, fuel filter and changing the fluid to redline in teh tranny and diff. Am i missing anything? what else should I check? Do you think by replacing these things i should be back up to a stock dyno of about 300rwhp?
__________________
__________________
