99bronzecoupe
Hello, new to the corvette world.
I just bought a 99 coupe with only 25,000 miles on it. It sat for 3 years in a garage(covered). I got a good deal but it comes with some gremlins.
First: After I got it running (new battery and gas) It throws the codes C1232 and C1233, Which I believe are the both front wheel speed sensors that are open or shorted. I haven't taken the wheels off to look at the sensors. Is this an easy fix?
Second: After I drove it for approximately 100 miles, 75% was highway at 75mph, the next day I discovered a puddle of power steering fluid on the garage floor.
Third:I found out the preceding battery had leaked and destroyed all of my vacuum hoses for the vents and blower. A/C doesn't work either.
I took it to the dealer to have them fix the A/C and get the vents working. I also told them to find out the leak on the power steering.
The dealer calls me back and tells me I need a brand new power steering pump that would cost $500.00 and a high pressure hose for another $130.00. He says there is fluid leaking out the front seal and the fitting on the hose is leaking.
Is it worth it to have them fix it? or should I buy the parts myself and attempt to fix it. I can work on cars. I just don't really have the necessary tools to do so. i.e. puller, lift, that sort of stuff.
Any help is appreciated.
