VAroute66
I need some advice from any of you who have backfit power steering into their small block midyears. One part of the power steering pump support bracket mounts to the engine at the motor mount. There are three bolts that connect the motor mount to the engine. Say the motor mounts hold 600 lbs total, which would be 300 lbs each side, and about 100 lbs each bolt for the six total. To remove one on one side would leave 150 lbs each for the remaining two on that side. It seems to me, but I am wrong alot, that it should not be a big deal to loosen the one to attach the bracket. Has anyone done this and have any guidance to offer? Am I going to remove that bolt only to find that something shifts, and I cannot get it back in. Thanks.
Dan
Dan
