I'm in the process of installing power steering on my 64. I won't get in to all the problems I've has so far at this time, but the issue I just ran up against is the pump/pulley assembly not properly aligning. It appears the bracket that bolts to the pump and attaches to the block is the culprit. Looks like it was welded together crooked. Anyone run into this problem before ?
Got the bracket from Corvette Central.
