My '81's power steering cylinder was leaking right where the ram enters the cylinder. I thought that I would just install a new seal kit (9 bucks from NAPA) rather than spend $70 on a rebuilt unit or $150 on a new one. The only problem is, there is a slight groove (cylindrical) worn on the ram that goes about 1/3 of the way around it, at about the midpoint of the travel. I'm thinking it was due to corrosion from the car sitting for a long time at some point. It is not rough, and hardly detectable, but you can feel it when running your finger over it.
Is this destined to leak again if I try to re-use it? Or should I take my chances? If not, what kind of luck has anyone had with a rebuilt one? I seem to remember some unhappy camper stories involving those.
Thanks, Dick
Thanks, Dick
