cwerve74
Just finnished the rebuild of the control valve on the power steering. Could not fine one of the torque specs. When you re-assemble the two halfs of the control valve what should be the torque on the two bolts?
Second question: What is the significance to the instruction that has you put the control spring locking washer "camfer side up?" I took that to be the pointed side of the horseshoe washer up.
