Power Window question
  • Thread starter Thread starter David8A1951
D
David8A1951
I just bought a new to me 2004 C5. When I was checking it over before the purchase I noticed that the passenger power window did not work so I insisted that the seller have it fixed. It turned out to be the electric motor for the window and after testing it to make sure it worked I closed the deal. I noticed later though that there is some wind noise from that window and after comparing both windows it appears that the passenger window is lower than the driver window when they are both all the way down and the passenger window seems to be a bit lower than the driver window when they are both all the way up so it appears it doesn't contact the rubber molding where it should hence causing the wind noise. Is it possible that when the motor was installed that the window wasn't lined up in track correctly?
David, welcome to the :CAC !!
If I recall correctly, there is an adjustment that can be made to the windows in the C5. I'll try to do a search in the C5 section and post a link if I find a pertinent thread.
Meanwhile, I'm going to move this thread to the C5 section where it will draw more attention and suggestions from other C5 owners.:thumb
:wJane Ann
Welcome to Corvette Action Center
Bill
