Power window
ldf44
Decatur, IL
2007 Victory Red Coupe
Passenger side power window on a '93 works SOME of the time. Any suggestions? I have taken off the door panel and find no loose connections. When it won't work, neither switch will work. When it does work, both switches work the window and the motor seems to power the window very well. Does seem like a bad connection. Has anyone had the same problem?
