Power window
ldf44
Decatur, IL
2007 Victory Red Coupe
The passenger side power window on my 93 works SOME of the time. I have taken off the door panel to look for a loose connection and cannot find anything. When it works, both switches will work and when it does not work, neither switch will power the window. When it works, the motor seems to power the window very well. Any suggestions??
I moved this to the C4 forum, where it will be seen by more appropriate members.
Try checking the connection on the motor. I had a problem like this and found out that the connection was just loose. Works fine now. If it is intermittent, it is probably an electrical thing.
