Ok all of you folks that have converted a powerglide to a four speed. I am rebuilding a 62' with a powerglide, but I need the upper and lower kickdown rods that connect to the kickdown bracket. The upper rod connects from the kickdown bracket to the carb and the lower rod connects from the kickdown bracket to the powerglide. I am also looking for the rod that connects from the neutral saftey switch to the tranny shift lever. Any help would be appreciated I have contacted the vast majority of vendors and most either don't have anything close, refer me to someone else with the same answer or we sorry don't have what you are looking for. Makes a nice catalog item but it is not in stock. If you have converted a 62' from a powerglide to a four speed I am interested in your kickdown rod setup. A 63' set of rods will also work. Pages B160, and B159 in the 62' AIM. Thanks
