S
sturgeon90293
I have a 2002 Z06 and have the Diablo Predator and I am unsure how to program it.I'll raise the top speed limiter and raise the rpm limiter( it will only allows 6600 rpm, 100 above the stock) I'll change the cooling fan to come on at 180 degrees. I am going to leave the timing as stock; I think that's wise. I have one basic question. Should I advance, retard, the timing, or should I just leave it alone? The only other nonstock item I have on the Z06 is the Donaldson Blackwing air filter system and a wider power duct made for the Z06
I have heard so many Z06 owners state that they didn't set the Predator up correctly, and had to reprogram it two or three times to get the full benefit.
I am asking if anyone has a good way to set the Predator's tuning so I can get the most out of it without going through the routine of trial and error.
If you have an answer, that's great. I you have a suggestion, I'm all ears.
