S
Scott81
Alright you tranny people, can anyone here can tell me the pros and cons of lockup converters in a 700r4 transmission? I plan on having one installed in the next month or so and here is what I understand so far, keep in mind that the only thing I know about trannies is that if I had to take one apart I'd be lost and have parts left over when I assemble it.
Sor far; I understand a lockup converter is good because there is less heat generated and with no slippage fuel economy is better. I have also been told it's no big deal to run a non-lockup converter as the heat generated is minumal. I have heard that there is a way to control lockup so that in 1-3rd gears around town you have non-lockup, then you are able to lockup the converter when going into OD.
Right now the motor is above stock (not by much) but will eventually be replaced by a strong 383. It will be used on the highway as well as being a weekend town cruiser.
OK, let's have your thoughts and ideas!
