S
sothpaw
What is the quickest way to drain out the old brake fluid, plus bleed the
system of air, for an early LT1 C4?
My Haynes manual shows the bleeding procedure but I can't find anything
that tells you what hose to pull to drain the fluid. Also, it mentions that
depending on where you introduce air, you might have to bleed one or more
wheels. I'd like to bleed just one if I could get away with it.
Also, are there any inexpensive gadgets I could get that would make this a one man job, so I wouldn't need an assistant on the pedal?
a
a
