Vref
My carb has a leak under the rear fuel bowl and it appears to be warped. It also has some, corrosion and needs some replating. I always restore things to original, any recommendations?
These guys below offer the service below, anyone use them or hear of experiences?
http://www.customrebuiltcarbs.com/
We offer a complete restoration service for your 1,2, or 4 barrel carburetor. We can restore your existing carb to show quality condition. All carburetors get completely disassembled and boiled out. Carbs then get stripped and redyed back to the original color. All base plates are line reamed and rebushed to eliminate lean idle miss. All new components are then used to reassemble the carburetor back to OEM standards and all necessary parts are replated and installed on the carb. The carburetor is then wet flow tested for air and fuel leaks. Pump,idle, and high speed circuits are then checked to assure you of a high quality restoration. We also offer a street restoration for your carb. If your car is not a show car but just a nice driver we can restore the carb without plating of the parts, all other aspects of the restoration are the same including redying and flow-testing.
