firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
Finally got enough of the body cut out (ouch, yes it was not easy to make the first cut) and fit to the frame.
Prothane body mount cushions
my friend's son with his much smaller hands sure fit in places our hands didn't
We finally got the body down on the mounts. We were able to get the #2, #3, #4 mounts and shims in place. Next we hung the passenger door, wasn't that a bunch of fun! on/off/on/off/on/off/on. After we fussed with pull the door forward, no pull it backwards.....just a lot of fussing. Finally got the door pretty good and decided to call it a day. We will get after the other door and then adjusting mounts #1 and #5.
I think when we get the shims and everything correct, I will put them in indivdual bags. Probably will have a single block machined to the correct thinkness of all shims for each mount.
After we get the body shimmed and adjusted, then I will get after glassing in the rear. Mike @ SRIII Motorsports did a nice job on the frame and working with me to set the wheel positions based on tire and wheel selection. When we get the other door and everything set, I will pull the car out from under the lift and off the wheel dollys and post some new photos.....
