Closed loop means that the computer is in total control of the fuel delivery through the injectors. If you're in constant open loop, the computer is not getting the OK from the coolant sensor. The computer will be operating in a "fixed mode"and as a result you will be running richer than normal--not a good situation. There's one of two reasons for this: first, the thermostat is sticking open and the engine cannot reach operating temperture. Or something is wrong with the sensor, wiring, or the computer.
The fact that your air sensor is negative could be the result of an open circuit or a bad sensor. Either way, the computer looks at the coolant sensor to determine closed loop operation. What temperature does your coolant sensor read whan the engine is warmed up. A quickie check you should do before you start the engine is: when the engine is cold both the air temp and coolant temp should be almost the same (withina few degrees of each other) if not, there's something wrong with the sensors, wiring, or the computer. Let me know.
