use a puller!
Bill Groom's right and your 72 pride and joy was born with a center bolt in end of crank snout...many of the chain auto parts stores (autozone does) will lend you a harmonic balancer remover/puller kit...or you can buy one from as little as $10 to $75. Pull the snout bolt first...then choose a "nipple" that won't damage the snout's female threads...then choose three bolts that fit balancer's inner-most hub's female threads...assemble the contraption and turn the puller's central bolt...this will force the balancer from the crank's snout...you do NOT have to do any prying...:nono do NOT attempt to pry or wedge the balancer from shaft:nono ...use a puller!!! Otherwise you can begin to list your troubles as: :cry ruined-bent timing cover, :cry ruined balancer...etc. While you're looking, see if you've a source for a tool to INSTALL the balancer...otherwise you'll have to be REAL CAREFUL and "pound" :bang it back in to place...not the best way but acceptable if done right. Get the idea??? Use the right tools for this job, pleeez!
If you're gonna put your old balancer back on...check it's snout for any groove that may have been worn into it by timing cover seal...auto parts houses sell a sleeve to repair this groove...it's cheap and effective...do it!
But, if you're changing to another balancer...make certain the new one is for your type motor. A 327/350 h balancer is not the same as 383/400 hb, but may look alike to the unitiated. Any questions on identifying balancer???...just email me clear photos of both front & back of balancer.
Jack
