Buckskin7T7V
I have a Q-Jet on my 77. When I first start it up for the day, I must pump the throttle four or five times before the fuel shoots in. Why does the float bowl empty the fuel. There are no external leaks. I am afraid that I will wash down the oil in the motor if I have to keep doing this. It does not require this pre-pumping the rest of the day. Only after it has sat around for eight or nine hours.
-if none of the recomendations given seem to help much, then i submit that your problem is not with the fuel-system, but rather you may have a tired battery, or a junk-battery such as an Exide; --was having the same problem, installed an Optima(sealed, spiral-wound cells) 950-cca Bat., --it now starts INSTANTLY!!! Obviously, in hindsight, the weak battery-current was being sucked-down to the level that there was nothing left to produce a Hot-spark needed to fire a cold engine...
