69MyWay
Ah,...........now the fun begins. I have started putting the 69 back together. Because I am changing so many things, this is a global approach. In other words, I can't just put in the wire harness, or gauges, or brakes, etc, it all has to be done in careful thought of the other systems I am squeezing in.
So far,
Headlights with electric actuators in.
pedals (we put new rubber on them and they are so nice)
hydraulic clutch master cylinder
steering column (converted to tilt and tele)
power brake booster
throttle pedal and cable (used a 79 cable and 69 pedal)
inner a/c box Vintage Air
rough wire harness stretched the length of the car.
brakes
springs
A arms etc.
So far, the worst job on the whole car was installing the power brake booster. It has a shaft with about five threads that comes out of the back and screws into a clip that is pinned to the upper part of the pedal. You only want to do this with the steering column out. One person just does not have enough hands (thank you Nikki).
We have been looking for the little things frist. For example, the brake, clutch, and throttle pedals, the rubbers that go in the inner fender openings above the a frames, and the rag joint that goes between the steering box and column. None of these are very expensive alone, but they add up over the long run.
So, I am just kind of rambling here, but also trying to give others an idea of the planning and time involved in one of these projects.
The fuel injection was shipped to Summit on 11/16 and will be here in a week or so. I must have that to complete the wire harness integration.
One major screw up to mention. I should have laced the main battery cable back into the car when I had it on its side. Now, I have to figure out a way to get under the car, measure, and reach past the drive shaft, trans, etc. and feed the cable and clip it to the floor.
Enough now, more later.
So far,
power brake booster
brakes
springs
A arms etc.
